Created:
Jul 2, 2021 12:24 PM
| Last Modified: Jun 11, 2023 4:15 AM(1619 views)
I have been trying to generate an interaction plot after GLM poission regression on JMP 14.0, but I can not do it there. I have an experimental data with three way interaction, and want to present the value in plot. Any suggestions or ideas?
The Graph > Surface Plot might provide a useful visualization of the three-way effect. Save the model as a column formula, then launch this platform with the column.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '398027' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '398027') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '398027') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
