EduardDerks
Functional Data Analyses returning DoE-factor (FDOE?)
Is it possible to do Functional Data Analyses like FPCA where the components reflect DoE-factors? (like in ASCA). It seems that FDOE profiler does something similar. Where can I fin it in JMP 18-pro?
Eduard P.P.A. Derks, PhD
Senior Data Scientist
Avient Protective Materials
Victor_G
Re: Functional Data Analyses returning DoE-factor (FDOE?)
Hi @EduardDerks,
Welcome to the Community !
Short answer : Yes, it is possible and you can try this analysis with the dataset "Functional Data/Formulation For Homogeneity DOE.jmp" from JMP sample library, using this guide from the JMP Help : Example of Functional DOE Analysis
I have done this kind of study and you can visualize the analysis, results and presentation here Use of Functional Data Explorer in a Mixture Design for Tribological Performance...
If you have more precise questions or follow-up questions, I would be more than happy to continue the discussion.
Hope this first answer will help you,
Victor GUILLER
