LaserGuy
Function to Count Rows Within Spec
I want to create a function that reads in a column, checks the number in each row on whether it is within spec, and output the passing count/total count/percentages.
This is what I have:
count_in_spec = Function( { col, lsl, usl },
	a=0; //pass count
	b=0; //all count
	for( i = 1, i <= N Rows(col), i++,
		if( col[i] >= lsl & col[i] <= usl, a++ );
		if( not(ismissing(col[i])), b++ );
	pctpass = 100*a/b;
	pctfail = 100 - pctpass;
	evallist({a, b, pctpass, pctfail});
dt0 = current data table();
colp = dt0:name("param") << get as matrix;
results = count_in_spec(colp, 0.15, 0.30 );
	countpass = results[1];
	countall = results[2];
	pctpass = results[3];
	pctfail = results[4];
While this works, I don't like the fact that I need to use "get as matrix". It's a bit clunky.
I would like a function that works simply by writing:
results = count_in_spec( "param name", lsl, usl);
How would I modify my function so it can work this way?
3 ACCEPTED SOLUTIONS
Re: Function to Count Rows Within Spec
EDIT: I can no longer recommend this solution--use MS's: it shows a way to do this using a column formula; not only should it run faster, but column formulas also have the benefit of supporting grouping variables.
-Brady
You can use the built-in matrix functions for this. I use <<get as matrix within the function, but I'm not sure how you'd avoid that without making the script more cumbersome.
Cheers,
Brady
dt = astable(J(1000, 1, randomnormal(0,3)), <<column names ({x}));
count_in_spec = function({col, lsl, usl},
	{default local},
	vals = column(dt, col) << get as matrix;
	vals = vals[loc(!is missing (vals))];		//remove missing rows
	nr = nrow(vals);							//get number of rows
	nPass = sum(lsl <= vals <= usl);
	evallist({nPass, nr, 100*nPass/nr, 100*(nr-nPass)/nr})  //be sure to EVAL the list!
//test it out...
{countpass, countall, pctpass, pctfail} = count_in_spec("x", -3, 4);
Using the Get Rows Where() function should get you want you want
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
count_in_spec = Function( {col, lsl, usl},
	result = N Rows( dt << get rows where( lsl <= As Column( dt, col ) <= usl ) )
colNames = dt << get column names(string, continuous);
resultColList = {};
resultCountList = {};
For(i=1,i<= 10 /*Nitems(colNames)*/,i++,
	specs = column(dt,colNames[i]) << get property("spec limits");
	If(isMissing(try(specs["LSL"],.))==0 & isMissing(try(specs["USL"],.))==0,
		result = count_in_spec(colNames[i],specs["LSL"],specs["USL"]);
		insert into(resultColList,colNames[i]);
		insert into(resultCountList,result)
new window("Results",
	outline box("In Spec Report",
		Table Box(
			string col box("Column", resultColList),
			number col box("Count", resultCountList)
ms
Super User (Alumni) ms
The Col Stat() functions are often efficient for directly summarizing table data, also with conditionals involved. Here's an example without the need for a matrix step.
	{default local},
	a = Col Sum( lsl < As Column( col ) < usl );
	b = Col Number( col );
	pctpass = 100 * a / b;
	Eval List( {a, b, pctpass, pctfail} );
results = count_in_spec( Column( dt, "height" ), 55, 70 );
-Brady
Cheers,
Brady
	{default local},
//test it out...
resultColList = {};
		Table Box(
ms
	{default local},
LaserGuy
Thank you everyone. I have explored all three categories of methods. I then realized I could have made things a bit easier for myself by using something like this:
	dt0 << clear row states;
	a=0; //pass count
	b=0; //all count
	cola = dt0:col << get as matrix;
	for( i = 1, i <= N Rows( cola ), i++,
			if( cola[i] >= lsl & cola[i] <= usl, a++ );
			if( not(ismissing( cola[i] )), b++ );
	pctpass = 100*a/b;
colp = "param1";
show(countpass);
show(countall);
show(pctpass);
show(pctfail);
colp = "param2";
results = count_in_spec(colp, 0.15, 0.30);
show(countpass);
show(countall);
show(pctpass);
show(pctfail);
The syntax for extracting LSL and USL properties from a column will be useful.
Level XIII
Just imagine how useful :folded_hands: is in spec (value)  will be.
With the new functionality any user can do the calculation in Graph Builder !
