I'm a n00b who is trying to run a full factorial. i'm just learning JMP and T&E so i don't really know what i'm doing yet.
I have 4 continuous factors. Let's say, my factors are birds observed in X park (where X represents a different local park). i don't know how I should do the levels of the factors. if I want that number to be randomized between 0 and 50, how should i run the test?
if i run the FF with 4 continuous factors and 2 levels (0 and 50), JMP only runs combos of 0 and 50. but technically, any number between 0 and 50 could appear. do i create 4 continuous factors with 50 levels so that each number between 0 and 50 appears? is keeping the 2 levels the best thing? should I do a custom DOE and make the levels binned by fixed numbers?
i also ran a FF with 4 categorical factors (4 levels: none, low, med, high).
