shasheminassab
How to subset top 10 highest values by year and location?
I have a dataset of daily ozone concentrations from multiple sites over several years. Is there a quick way to subset the top ten highest concentrations at each site and year?
Re: How to subset top 10 highest values by year and location?
Here is an example of a simple way to create a table with just the top 10 for each group(site)
names default to here(1);
dt=// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "$SAMPLE_DATA/Big Class.jmp" );
dt << sort(by(:sex, :height), order(descending,descending), replace table(1));
dt<< select where(col cumulative sum(1, :sex) <=10);
dtFinal = dt << subset(output table("Top 10"), selected rows(1), selected columns(0));
derchieh
Hi, I am very happy to learn about "select where(col cumulative sum(1, :sex) <=10)".
I am wondering if I can push it further, say if I want to select top 5 for male, and top 7 for female? Many thanks in advance.
mmarchandFSLR
dt << select where( Col Cumulative Sum( 1, :sex ) <= Match( :sex, "M", 5, 7 ) );
You can create formula to get top10, use summary or tabulate. And then depending on how your data looks like you might need additional calculation to easily get the top10
