This happens because you try to plot a formula with 3 inputs vs. a single X-Axis.
The table shows that the 2nd and 3rd input is constant.
But Graph Builder doesn't know, because the parameters are not used in Graph Builder.
And this is the solution: Just put the parameters somewhere where they don't hurt (Group X/Y) - and you will get the curve ...
![hogi_0-1694197519448.png hogi_0-1694197519448.png](https://community.jmp.com/t5/image/serverpage/image-id/56411i2AF4F908026CC48F/image-size/medium?v=v2&px=400)
Names Default to Here(1);
dt << New Column( "age/height", Formula( :age / :height ));
dt << Graph Builder(
Variables( X( :height ), Y( :"age/height"n ), Group X( :age ) ),
Elements( Formula( X, Y, Legend( 11 ) ) )
