David_Burnham
Jul 13, 2011
Fonts Misbehaving
Here's some test code:
New Window("Test",
	Border Box(Top(20),Bottom(20),Left(20),Right(20),
		LineupBox(NCol(2),
			Text Box("First Name", <<Vertical Alignment("Center")),
			Text Edit Box("",<<Set Font Size(12), <<Set Width(300)),
			Text Box("Surname", <<Vertical Alignment("Center")),
Depending on how you enter a text field (mouse-click or tab) and based on time of day or some other random event I get either the font size I requested, or not ...
The small font size only occurs at the time when input is typed, but its still inconsistent and ugly
I initially assumed it was a JMP 13 issue because there is a lot of inconsistent font behaviour for display boxes in this release but that's not the case - it also occurs with version 12.
Any ideas as to what is going on?
-Dave
Craige_Hales
Mar 21, 2013
Solution
Re: Fonts Misbehaving
Thanks, taking a look at it.  I think JMP is not always sending the current size to the edit control and it winds up using a default size.
Craige
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
The problem with fonts behaving inconsistently was a bug in JMP 13. It was corrected in JMP 13.2 and beyond.
-Jeff
David_Burnham
Jul 13, 2011
Note to self: insert code != insert JSL script
-Dave
Jeff_Perkinson
Community Manager
Jun 23, 2011
I fixed your post to use the JSL formatting.
-Jeff
Jun 22, 2012
I was able to replicate your example in a release of JMP, and then I went to JMP 13 and I could not replicate it.  I believe the reason I could not replicate it is that I have changed the default font and font sizes.
This is a courious one.
ih
Sep 30, 2016
I can replicate the behavior in JMP 13 (I have not changed any default fonts).
Craige_Hales
Mar 21, 2013
Solution
Craige
Craige_Hales
Mar 21, 2013
Done, thanks!
Craige
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
