sanchezpeinado
Font size for the 'Label by Value' inside the graph builder
How can I permanently change the Font size for the 'Label by Value' inside the graph builder?
Re: Font size for the 'Label by Value' inside the graph builder
For me (I'm using JMP18.2 with Windows 10) it seems to work fine for bar charts.
With defaults for me
After setting Graph Label font size to 20 and rerunning the script to create same graph
Changing the Graph Label font preference
Though, this will most likely change it for other than just graph builder
sanchezpeinado
Thank you. I have done that many times, and the font inside the graph stayed the same.
