New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
on here appreciating this older tip about using Fit Model by not centering polynomials and just thought I'd note that in Fit Model the Expanded Estimates are a little less cryptic, especially if there were more groups. I'll be using those where I want to get the slopes out of there with JSL but can see that the plot from Fit Y by X is nicer.
Thansk...however when i adopt the below approach the graph of Y verus TIME by group - doesnt appear to haev a common intercept. Howevre if i change Time to an ordinal variable..seems to work OK.
Here is another approach, using the Nonlinear platform. Attached is an example: you need to set parameters to be solved for, with a single intercept but varying slope parameters for the two groups. The script is saved for the solution.
