mostarr
Fit x by y on subset of data vs other subset of data
Hi, this is not a JSL question like most of my others are.
I have some data, and I'd like to fit x by y on it, one half of the data vs the other half of the data. I realize a caveman way of doing this is cut pasting the second half of the data into a new column. But I'd really rather not adjust the table like that. Any solutions? I was advised to use the Split function under Tables so I could toy around with that, but is that all there is to it? Anything more specific?
Thank you hugely in advance, and thank you so much for all the help you've been providing to this date. You are an amazing and amazingly patient community.
Best,
Mike
3 ACCEPTED SOLUTIONS
Jeff_Perkinson
Re: Fit x by y on subset of data vs other subset of data
If I'm reading your question correctly, it sounds like you have a single column of data that has both your X values and Y values in it.
Do you have a column that identifies whether a row is an X or Y value? Do you have another column (or combination of columns) that identifies which XY pair that row belongs to?
For example, in the table below Value has both X and Y values. Measure identifies whether a row is a height or weight value, and name, age, sex together identify a unique entity for that height or weight.
If this is the kind of data you have then yes, Tables->Split is exactly what you need.
You would complete the Split dialog with Measure in the Split By role, Value in the Split Columns role, and name, age, sex in the Group role. 
name
age
sex
Measure
Value
KATIE
12
F
height
59
KATIE
12
F
weight
95
LOUISE
12
F
height
61
LOUISE
12
F
weight
123
JANE
12
F
height
55
JANE
12
F
weight
74
JACLYN
12
F
height
66
JACLYN
12
F
weight
145
LILLIE
12
F
height
52
LILLIE
12
F
weight
64
TIM
12
M
height
60
TIM
12
M
weight
84
JAMES
12
M
height
61
JAMES
12
M
weight
128
ROBERT
12
M
height
51
ROBERT
12
M
weight
79
BARBARA
13
F
height
60
BARBARA
13
F
weight
112
ALICE
13
F
height
61
ALICE
13
F
weight
107
SUSAN
13
F
height
56
SUSAN
13
F
weight
67
JOHN
13
M
height
65
JOHN
13
M
weight
98
JOE
13
M
height
63
JOE
13
M
weight
105
-Jeff
Hi @mostarr,
Ya, split is basically it. @Jeff_Perkinson as given a way to do it if you know what to split by. If there is only a single column in your data, then like copy and paste will be the quickest.
Chris Kirchberg, M.S.2
www.jmp.com
Another option besides splitting your datatable is creating a new column to randomly group your rows (or could systematically group them by row counts) into different groupings and use that grouping as an overlay such as in this example:
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
// New column: Group
Data Table( "Big Class" ) << New Column( "Group",
	Character,
	"Nominal",
	Formula( If( Random Integer( 2 ) == 1, "Group A", "Group B" ) )
// Report snapshot: Big Class - Graph Builder
Graph Builder(
	Size( 534, 456 ),
	Variables( X( :height ), Y( :weight ), Overlay( :Group ) ),
	Elements(
		Points( X, Y, Legend( 5 ) ),
		Line Of Fit( X, Y, Legend( 7 ), Equation( 1 ) )
Jeff_Perkinson
name
age
sex
Measure
Value
KATIE
12
F
height
59
KATIE
12
F
weight
95
LOUISE
12
F
height
61
LOUISE
12
F
weight
123
JANE
12
F
height
55
JANE
12
F
weight
74
JACLYN
12
F
height
66
JACLYN
12
F
weight
145
LILLIE
12
F
height
52
LILLIE
12
F
weight
64
TIM
12
M
height
60
TIM
12
M
weight
84
JAMES
12
M
height
61
JAMES
12
M
weight
128
ROBERT
12
M
height
51
ROBERT
12
M
weight
79
BARBARA
13
F
height
60
BARBARA
13
F
weight
112
ALICE
13
F
height
61
ALICE
13
F
weight
107
SUSAN
13
F
height
56
SUSAN
13
F
weight
67
JOHN
13
M
height
65
JOHN
13
M
weight
98
JOE
13
M
height
63
JOE
13
M
weight
105
-Jeff
mostarr
Is there a basic way to do this in JSL? Split()?
mostarr
Actually I am following the syntax in the Scripting Index and results are not as expected. The split in Split(Split()) excludes that column, instead of isolating it, and it doesn't seem it shows the split by column. It's just pretty messy and I don't know that it's working properly.
Jeff_Perkinson
After completing the Tables->Split by hand one time, you can find a Source script in the resulting data table. That will have the script for doing the split. No need to write it by hand. You can copy/paste it into your script.
This is true for most of JSL. Do it by hand then get the script for it from JMP.
Let JMP write your script!
-Jeff
Hi @mostarr,
www.jmp.com
mostarr
Thanks for the responses.
I found that a specific type of Split worked perfectly. Now I am wondering if there is a way to save the script automatically? Or do I have to rewrite it manually in JSL?
Mike
	Character,
	"Nominal",
Graph Builder(
	Size( 534, 456 ),
	Elements(
