キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
言語を選択 翻訳バーを非表示
nkormanik
Find slope for a row of data, not a column
Data are by subject over time, across a row.  See the following example:
columns _1 _2 _3 _4 _5 _8
subject(001) data -0.069965723 0.492749371 0.955245597 1.346963522 1.701118239 2.523141195
I have thousands of such rows where the slope is needed.
All I really need is the slope for each series of numbers in the row.
A new additional column following each series should contain the slope value for that particular series.
I've asked on a SAS forum if SAS can handle this.  Wondering if JMP can??  Any help would be greatly appreciated.
Nicholas
3件の返信3
ron_horne
Re: Find slope for a row of data, not a column
hi nkormanik​,
the answer is yes.
in general you would need to transpose the data and do the calculations. assuming the data table is too big for that i think it is easier to transpose a matrix. therefore, the process in general involves extracting the data into a matrix, transposing it and calculating the slopes. have a look at this. it does all the dfferent steps for illustration purposes. it is not very robust (if you have missing values) or anything funny.
best,
ron
// create a data table
dt = new table ("data in rows",
      add rows (100),
      new column ("Subject", formula (row())),
      new column ("slope"),
      new column ("R2"),
      add multiple columns ("column", 20, numeric)
// set values for the data columns
for (i=4, i<=23, i++,
      :column (i) << formula ((i/2) + Random Normal()) << eval formula << delete formula ;
// start working
// get the table as a matrix
datamatrix = dt<<GetAllColumnsAsMatrix;
// remove the columns not used for regression calculations (columns 1-4)
datamatrix [ 0 , 1::3] = [];
// transpose the matrix
data = datamatrix`;
// make an x variable for time.
X = (1 :: ncol(datamatrix))`;
// add a column of 1's for the intercept term
X = J(Nrow(X),1) || X;
//now we have all the data we need for the calculations in matrix form
for (irow=1, irow<=nrows(dt), irow++, // for each row
// extract individual data one by one
Y = data [0,  irow ];
// compute least squares estimates
β = Inv(X`*X)*X`*Y;
dt:slope[irow] = β[2];
// compute R2
N = NRows(Y);
Ybar = Mean(Y);
R2 = (β`*X`*Y - N*Ybar^2)/(Y`*Y - N*Ybar^2);
dt:R2[irow] = R2;
ms
Super User (Alumni) ms
Here is an example of a column formula to calculate the slope across columns. It is not clear what the X values are, but I assume they are defined by the column names as in your example. As you can see the the X matrix is now hard coded. The formula could be made more general if the X values were held in e.g. the first row (or in a table variable).
// Example table
dt = New Table("Slope_Across_Columns.jmp",
    Add Rows(2),
    New Column("Subject", Character, Values({"001", "002"})),
    New Column("_1", Values([-0.069965723, 2])),
    New Column("_2", Values([0.492749371, 4])),
    New Column("_3", Values([0.955245597, 6])),
    New Column("_4", Values([1.346963522, 8])),
    New Column("_5", Values([1.701118239, 10])),
    New Column("_8", Values([2.523141195, 16]))
//Formula expression
F = Eval Expr(
    Local({i = 1, n = Expr(N Col(Current Data Table()) - 1), X = J(n, 1, 1) || [1, 2, 3, 4, 5, 8], Y},
        Y = Matrix(Repeat({i++ ; Column(i)[]}, n));
        (Inverse(X` * X) * X` * Y)[2];
//Add formula column
dt << New Column("Slope", Numeric, Formula(Name Expr(F)));
Here is another method.  It has only one advantage, in that the script just duplicates what you could do running JMP interactively.  I have attached a sample data table that I developed the script around.
// Set a pointer to the sample data
names default to here(1);
dt = current data table();
// Stack the 6 data columns from each row
stacked = dt << Stack(
       columns( :_3, :_4, :_5, :_6, :_7, :_8 ),
       Source Label Column( "Label" ),
       Stacked Data Column( "Data" )
// Create a new column that represents the time factor
stacked << new column("time",formula(Num(Substr(:Label, 2, 1)) - 2));
// Run the analysis on the data, by each row(student)
biv=stacked<<Bivariate(invisible,
       Y( :Data ),
       X( :time ),
       Fit Line( {Line Color( {213, 72, 87} )} ),
       by(_1)
// Create a data table from the estimates output
dtslope=report(biv[1])["Parameter Estimates"][1]<<make combined data table;
// Get rid of the intercept data
dtslope<<select where(:term == "Intercept");
dtslope<<delete rows;
// Select the columns that are not wanted and delete them
dtslope:x<<set selected(1);
dtslope:y<<set selected(1);
dtslope:term<<set selected(1);
dtslope:Name("~bias")<<set selected(1);
dtslope:std error<<set selected(1);
dtslope:t ratio<<set selected(1);
dtslope:Name("prob>|t|")<<set selected(1);
dtslope<<delete columns;
// Rename the Estimate column to Slope
dtslope:Estimate<<set name("Slope");
// Add the slope to the original data table
dt<< Update(
       With( dtslope ),
       Match Columns( :_1 = :_1 )
おすすめの記事
