All of what I am going to show you below is covered in the Using JMP book
Help==>Books==>Using JMP
What needs to be done is to create a new column in your data table, and apply a formula to the column.
1. Open the stacked data table and click on the red triangle in the column area above the row state column. Select "New Column"
![nc1.PNG nc1.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6514i512BB9CA06BAD00C/image-size/large?v=v2&px=999)
2. The Column Info window will open. Change the name of the new column to whatever you want(I chose "Label 2"). Also change the Modeling Type to "Character"
![nc2.PNG nc2.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6515i62547611341FA0C4/image-size/large?v=v2&px=999)
3. Click on OK and then Right Click on the header area of the new column and select "Formula"
![nc3.PNG nc3.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6516iD9299F53596D5E34/image-size/large?v=v2&px=999)
4. In the formula editor, double click on the box titled "No Formula"
![nc4.PNG nc4.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6517i041DADD08DDB6A3F/image-size/large?v=v2&px=999)
5. Rather than doing the point and click formula building that we could do, with this simple formula, we just need to type it into the box
![nc5.PNG nc5.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6518iE5DE49AD5E5B3DAA/image-size/large?v=v2&px=999)
6. Once the typing is done, just click on OK or Apply and the formula will generate the new values
![nc6.PNG nc6.PNG](https://community.jmp.com/t5/image/serverpage/image-id/6519iB8E86C3EDF78313C/image-size/large?v=v2&px=999)
You can now use this new column in your Tabulate Platform
