See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
Filter row item by comparing multiple parameters related the item using a script
Neo
Neo
I have attached example data from which I need to extract the row for which the yield is minimum for a given PartID. I would like to do this using a script.
This I need to do for each PartID and then have a table with only the filtered rows (i.e. [PartID], [Parameter] [(min-) Yeild]).
Note, I have deliberately put identical yield for part C as I may have similar data and would like to handle such using the script. I am on JMP13.
Thanks.
Neo
Neo
Re: Filter row item by comparing multiple parameters related the item using a script
Ok figured it out, the corrected script is (it should be theMin = Minimum( :Yield) inside the for loop as well)
Summarize( dt, thePartID = by( :PartID ), theMin = Minimum( :Yield) );
dt << clear select;
For( i = 1, i <= N Items( thePartID ), i++,
	dt << select where(
		:PartID == thePartID[i] & :Yield == theMin[i],
		current selection( "extend" )
dtSelected = dt << subset( selected rows(1), selected columns(0));
Here is one way to handle your request:
Summarize( dt, thePartID = by( :PartID ), theMin = Minimum( :Parameter ) );
dt << clear select;
	dt << select where(
		:PartID == thePartID[i] & :Parameter == theMin[i],
Neo
Neo
Thanks. Running your script directly gives me the following error
Column Must be Numeric in access or evaluation of 'Parameter' , :Parameter/*###*/
In the following script, error marked by /*###*/
Summarize( dt, thePartID = by( :PartID ), theMin = Minimum( :Parameter/*###*/ ) );
dt << clear select;
	dt << select where(
dtSelected = dt << subset( selected rows( 1 ), selected columns( 0 ) );
Perhaps the third line should be
Anyway running the script give me with the above line.
Empty()
I have attached the data table with script inside.
Neo
Neo
dt << clear select;
	dt << select where(
Sorry for the misdirection......I made up a data table to test the script on, and in error, I used the :Parameter name as the target column, instead of the :Yield column.
