Thomas1
Fill Color for Normal Box Plots in Graph Builder
Is there a effective way to color of or example five box plots (normal style) with fill color in graph builder by using a add-in or JSL? The five different colors should be defined via RGB values.
I don't want to use box plots with style solid, because of faded colors and missing fences. Attach a file with one colored box plot.
8 REPLIES 8
cwillden
Re: Fill Color for Normal Box Plots in Graph Builder
RGB Color() seems to be what you're looking for.  For example:
Graph Builder(
	Size( 754, 490 ),
	Variables( X( :BoxNo ), Y( :RandomVaules ), Overlay( :BoxNo ) ),
	Elements( Box Plot( X, Y, Legend( 4 ), Outliers( 0 ) ) ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				4,
				Properties( 0, {Line Color( -14948892 ), Fill Color( RGB Color(100, 0, 0) )} ),
				Properties( 1, {Line Color( -3636920 )} ),
				Properties( 2, {Line Color( -5091146 )} ),
				Properties( 3, {Line Color( -9981603 )} ),
				Properties( 4, {Line Color( -16744192 )} )
-- Cameron Willden
Thomas1
Thanks for your fast reply. That points in right direction. How does an JSL code in an add-in look like, in order to fill up to 5 empty boxes withe RGB colors?
cwillden
I'm not sure what you're looking for.  Do you want to have the user choose the colors in a dialog?  You want it to work for exactly 5 groups or any number of groups? The answer would vary quite a bit depending on the intended use of the add-in.
color1 = RGB Color(100,0,0);
color2 = RGB Color(50,120,50);
color3 = RGB Color(210,0,180);
color4 = RGB Color(130,130,200);
color5 = RGB Color(10,190,70);
Graph Builder(
	Size( 754, 490 ),
		Dispatch(
			"400",
			ScaleBox,
			{Legend Model(
				4,
				Properties( 0, {Line Color( -14948892 ), Fill Color( color1 )} ),
				Properties( 1, {Line Color( -3636920 ), Fill Color( color2 )} ),
				Properties( 2, {Line Color( -5091146 ), Fill Color( color3 )} ),
				Properties( 3, {Line Color( -9981603 ), Fill Color( color4 )} ),
				Properties( 4, {Line Color( -16744192 ), Fill Color( color5 )} )
-- Cameron Willden
Thomas1
I'm interested in an add-in, which I can apply on every new box plots created with the graph builder, in order to fill the boxes with the specified corporate colors.
cwillden
I'm sure it's do-able, but that's too big of a task to do for free :)
-- Cameron Willden
Thomas1
Thanks for the reply. Do you have any suggestions in which direction the add-in should go?
cwillden
The tricky thing is going to be making the add-in robust to different situations.  What if someone nests 2 factors in the X drop zone?  What if there's Group X and Group Y variables?  You need to figure out at the beginning what the limitations of your add-in are going to be.
Then you need to kind of storyboard out an approach to the whole add-in so you can figure out what sub-tasks you will need to figure out. Here's a rough idea of what that might look like:
  1. Present the user with a dialog window for casting columns into specific roles for the plot.  This will act as a front end to Graph Builder
  2. When the user specifies a column for the X-axis (grouping variables), the script determines all the unique values in that column.
  3. The dialog window is updated with a lineup box containing a list of the levels of X, and dropdown boxes that allow the user to select a color for each level of X.
  4. User presses OK, which will do the following:
    • Stores all inputs into variables for execution
    • check that all required inputs are provided.  If not, return a descriptive error message
    • Build the Graph Builder script and execute it.
After you map everything out, work on 1 piece at a time.  Just make sure the pieces are going to fit together in the end.
-- Cameron Willden
Thomas1
It can be very tricky to work with fill colors and Overlay mode in Graph Builder. If the boxes are reduced by a local data filter and one goes back to origin number of boxes, the fill color is partly disappeared.
Thats the reason why I’m interested in an add-in for fill colors.
May be a part solution could be helpful. In almost every case I could get or recover the fill color by adding or renewing the following JSL code.
Dispatch(
"400",
ScaleBox,
{Legend Model(
4,
Properties( 0, {Line Color( -14948892 ), Fill Color( 67 )} ),
Properties( 1, {Line Color( -3636920 ), Fill Color( 69 )} ),
Properties( 2, {Line Color( -5091146 ), Fill Color( 68 )} ),
Properties( 3, {Line Color( -9981603 ), Fill Color( 72 )} ),
Properties( 4, {Line Color( -16744192 ), Fill Color( 73 )} )
Is there any way to build an add-in to add only this part? In this case it would be possible, to run the add-in in graph builder and to repair the fill colors.
Attached the JSL code for the uploaded file.
