dn610
Extracting the Last Word
Hi - If I want to extract the last word in the Name column below, what would be the best way to so?
Re: Extracting the Last Word
Right click on the column header you wish to get the value from and create new formula column with Last Word
then you can take a look at the formula if needed
You can also do the extraction with Recode for example
Jeff_Perkinson
The Word() function is perfect for this. Use "-1" to get the last word.
If you learn only one Formula Editor function, Word() is the one
-Jeff
dn610
Thank you!
Jeff_Perkinson
-Jeff
