Mariana_Aguilar
Extracting mean and shape functions in FPCA to data table
Hi everyone,
I'm working in JMP 18 Pro – Student Version and I have run an FPCA model. I need to export the shape functions (eigenfunctions φ(t)) and mean function as numeric columns in a data table so I can use them outside JMP.
I can see the FPCA plots for:
  • Mean Function
  • Shape Function 1
  • Shape Function 2
But I cannot find a reliable way to extract these curves into a data table.
What I have already tried:
  • Right-clicking the FPCA curve → Copy, Copy Frame Contents, Edit, Journal, etc.
  • "Make Data Table" options — not available in my menus
  • Graph Builder → save script → to data table (only gives shape scores, not the curve)
  • Copying curve graphics into a journal and trying ā€œCopy Tableā€ (no result)
  • Extracted ā€œShape Functionā€ columns from the FPCA output, but those are scores per sample, not the φ(t) curve values
  • Checked preferences, right-click axes, and data filter options
So far, everything either gives images or PCA scores — not the full shape function vector sampled over wavenumbers.
I suspect I am just missing the correct extraction method or the student license may not expose it the same way.
If anyone knows the proper procedure or if there is a script to dump FPCA component functions into a table, I would really appreciate guidance. This seems simple so I may be missing a menu path in JMP 18 Pro Student Edition.
Thank you!
Re: Extracting mean and shape functions in FPCA to data table
Thanks for tagging me, @jthi! If I'm understanding correctly, Save Summaries is what you're looking for, but JMP hides the columns with the actual formulas in them by default. Here's a quick example of how to extract and use these formulas, using the attached data table.
  1. Run the FDE script in the attached data table (just some simple curves).
  2. Red Triangle by Function Summaries > Save Summaries
    1. The Shape functions are in the columns list on the left, but are hidden, so they don't show up in the data table.
    2. One way to use them is with the custom profiler. Graph > Custom Profiler > Choose one or more of the shape functions.
    3. You can then add a profiler (Red Triangle > Prediction Profiler) then set up the simulator (Prediction Profiler Red Triangle > Simulator) to make a table with output from the formula.
    4. The resulting table has values from the formula which can be used in the Graph Builder, etc.
    5. You can also use things like the Formula Depot and Copy/Paste to move the formula itself to different tables.
Are you possibly looking for Save Summaries?
Predictive and Specialized Modeling > Functional Data Explorer > Functional Data Explorer Platform ...
Save Summaries
Saves the summary statistics specified in each Function Summaries report to a new data table. The name of the new data table describes the model fit. This data table contains formula columns for the eigenfunctions, mean function, prediction function, and conditional prediction function for each of the Y variables. In the data table, there is a profiler script for each Y variable that launches the prediction profilers for the prediction and conditional prediction formulas. These formulas are functions of the input variable, the ID variable, and the eigenfunctions.
Mariana_Aguilar
Thank you for your kind reply... i've actually clicked on that button several times but when i do, I get a table like this... I was expecting a column that would be my wavenumbers (im working with spectral data) vs absorbance for each point (around 1762 rows) so that i could graph back the mean and shape functions.  Does this have anything to do with me analyzing the data in wide format? (wavenumbers are columns and rows are individual samples) for analysis I've selected the row as functions...
Thank you :)
I think that could be the reason (I'm not that familiar with FDE platform) though I couldn't replicate that with some example data I found from JMP (I'm using JMP Pro 18.2.0). Could you possibly stack your data and use that? I tried using Save Data from FDE with wide data and it did give me stacked data so I would guess JMP is using stacked data with FDE (at least on some parts).
I'll tag @Jed_Campbell from JMP as I do remember him answering some FDE questions
Mariana_Aguilar
Thank you ... Unfortunately, I've tried all three options in the Functional Data Explorer (stacked, rows as functions, and columns as functions ) and none of them worked. When I click save summaries, it shows a table where each row is the sample ID rather than the wavenumbers used to construct my mean and shape functions... It's strange that you couldn't replicate my findings using JMP 18.2... may be there's a workaround that I should do for JMP's student version? Or perhaps I'm missing something?
To my knowledge JMP Student is same version of JMP as JMP Pro. How did you fill in the platform launcher?
This is JMP's example table "Functional Data/NMR DoE.jmp" and I removed "FDE X" column properties.
Then if I just pick some model
And then Save Summaries
I will end up with
(for this example I did use JMP Pro 18.2.1)
If you repeat this example, will you end up with similar results as I did?
Mariana_Aguilar
Thank you!!!! this approach worked! I'm so happy! I've been struggling with this for quite some time! As a suggestion, it would be nice if the extended table could also be generated from the FDE platform. Other than that, I've found the platform extremely useful to work with spectral data :). @jthi, thank you also for your help. Have a nice Friday!
