JMP will suspend normal business operations for our Rest and Recharge Day on Friday, October 2, 2026.
Go to the Column Info for the formula column and select a Format to use. Since there is not a direct format that will just display the Hour component of a time based column, you need to select a "Custom" format. The value you need to specify for the custom format is
Is there a way to do this without a script? I am not familiar with JMP programming but I run sas programming.
Is not then how to recode this with my actual variable name that is called "hours" and is in duration ( hr:min) formant. I would like to create a col hours1 and extract the hours and do the rounding?
