This website uses Cookies. Click Accept to agree to our website's cookie use as described in our Privacy Policy. Click Preferences to customize your cookie settings.
Go to the Column Info for the formula column and select a Format to use. Since there is not a direct format that will just display the Hour component of a time based column, you need to select a "Custom" format. The value you need to specify for the custom format is
Re: Extract hours to the nearest hours from duration ( hour:min) format
This widget could not be displayed.
Created:
Jun 28, 2020 03:50 PM
| Last Modified: Jun 28, 2020 12:50 PM(2506 views)
| Posted in reply to message from txnelson 06-28-2020
Thank you
Is there a way to do this without a script? I am not familiar with JMP programming but I run sas programming.
Is not then how to recode this with my actual variable name that is called "hours" and is in duration ( hr:min) formant. I would like to create a col hours1 and extract the hours and do the rounding?
