I hope someone in the Community has a better solution than what I have come up with. I am not aware of a direct way to add the spanning headers to the column headers in an output data table. However I have written an example script that can do what you want.
It takes an LCA analysis output
and output the Parameter Estimates table with the Spanning Headers prefixed to each column
Here is the example script
// Run a LCA
dt = Open( "$SAMPLE_DATA/Car Poll.jmp" );
dt << Latent Class Analysis(
Y( :sex, :marital status, :country, :size, :type ),
Set Random Seed( 12345 ),
Number of Clusters( 3 ),
// Create an output table will all header names in each column's name
obj = current report()[OutlineBox(1)];
// Get the number of tiles that span across columns
numSpans = Length( (obj << xpath( "//ColSpanBox" )) );
// Loop across the spanning titles and add the title as a prefix to the column name
For( span = 1, span <= numSpans, span++,
// Get the header
theHeading = obj["Parameter Estimates"][Col Span Box( span )] << get heading;
// Get the column names for the current spanning header
theCols = obj["Parameter Estimates"][Col Span Box( span )] << get text;
// Loop across each column name in the span
subColNum = 1;
While( Try( Word( subColNum, theCols, "\!n\!t\!r" ), "" ) != "",
targetCol = Word( subColNum, theCols, "\!n\!t\!r" );
// Loop across all numeric column and when a match is found change the column name
numCol = 2;
While(
Try( obj["Parameter Estimates"][Number Col Box( numCol )] << get heading, "" )
theNumberColBoxHeader = obj["Parameter Estimates"][Number Col Box( numCol )]
<< get heading;
If( targetCol == theNumberColBoxHeader,
set heading( theHeading || " " || targetCol )
numCol++;
subColNum++;
// Create the output data table
obj["Parameter Estimates", Table Box( 1 )] << Make into data table;
