Lharbicht
Export all control charts from By column on one page for export to powerpoint
I have a script that I use to make 6 control charts for 20 separate groundwater monitoring wells using the By portion in the script. I would like to add on to the end of the script so I can print the 6 control charts for each separate monitoring location on one page in a powerpoint presentation Result in a powerpoint presentation that is 20 pages long, with 6 graphs on each page. I'm looking for some advice on where to start for this task? Here is the script I'm using to make the charts:
Control Chart Builder(
	Show Capability( 0 ),
	Variables(
		Subgroup( :SAMPLE_DATE ),
		Y(
			:Chloride,
			:Cl_TDS,
			:Sodium,
			:Total Dissolved Solids,
			:Sulphate,
			:Calcium
	By(:LOC_NAME)
Thank you!
Re: Export all control charts from By column on one page for export to powerpoint
Below is a script that creates the PowerPoint output from your Example data table
// Get a list of the LOC_Name's that are in the data
Summarize( dt, bygroup = by( :LOC_Name ) );
// Create a display window to put the graphs into
Nw = New Window( "Control Charts" );
// Loop across all of the LOC_Name's creating the six control
// charts
For( i = 1, i <= N Items( bygroup ), i++,
	// Create the Outline Box to hold the 6 charts
	ob = Outline Box( "Control Charts for LOC_Name=" || byGroup[i] );
	// Create a display box of three objects wide
	// With the 6 control charts, it will make it a
	// 2 row 3 column output
	lub = Lineup Box( N Col( 3 ) );
	// Create the 6 charts
	ccb = dt << Control Chart Builder( invisible,
		Show control panel( 0 ),
		Variables(
			Y(
				:Chloride,
				:Cl_TDS,
				:Sodium,
				:Sulphate,
				:Calcium
		show limit summaries( 0 ),
		where( :loc_name == Eval( bygroup[i] ) )
	// Loop across the output pulling out the 6 Picture Boxes
	// that contains the desired output for each control chart
	// and add them to the Lineup Box
	For( k = 1, k <= 6, k++,
		lub << append( Report( ccb )[Picture Box( i )] )
	// Close the no longer needed Control Chart Builder window
	Report( ccb ) << close window;
	// Add the contents of the Line Up Box to the Outline Box
	// but make it a single object so when saved to pptx it will
	// be treated as a single graph
	ob << append( lub << get picture );
	// Add the current outline box to the display window
	nw << append( ob );
// Save the graphs to PowerPoint
nw << save presentation( "$TEMP/myppt.pptx" );
// Display the PowerPoint output
Open( "$TEMP/myppt.pptx" );
Please take the time to study the script so you understand the approach I took, so you can make any adjustments needed.  The section in the Scripting Guide on Display Trees will give you the background on how I picked apart the output, and built it back into a new display format.
8 REPLIES 8
I recorded a Mastering JMP session a few months ago in which I demonstrate how to automatically save reports to PowerPoint (Mastering JMP Sharing Your Results, starting at 33:30).  This might be a good place to start.  Please take a look and let me know if this points you in the right direction.
Lharbicht
Hi!
Thank you for your reply. I watched the video and it gave me the right info for putting the control charts in powerpoint and having them update automatically. That is definitely helpful. I have now added on to my script to save each set of my control charts as a jpg in a specific folder, and I will insert those into powerpoint as you said (with a link). However, my last piece of the puzzle involves arranging the graphs in my jpgs three graphs across and two down. Currently they are exporting 6 down, which doesn't look nice on a powerpoint slide. See attached picture.
Thanks for your help!
	Variables(
		Y(
			:Chloride,
			:Cl_TDS,
			:Sodium,
			:Sulphate,
			:Calcium
		Dispatch( {}, "Chloride Limit Summaries", OutlineBox, {Close( 1 )} ),
		Dispatch( {}, "Cl_TDS Limit Summaries", OutlineBox, {Close( 1 )} ),
		Dispatch( {}, "Sodium Limit Summaries", OutlineBox, {Close( 1 )} ),
		Dispatch( {},
			"Total Dissolved Solids Limit Summaries",
			OutlineBox,
			{Close( 1 )}
		Dispatch( {}, "Sulphate Limit Summaries", OutlineBox, {Close( 1 )} ),
		Dispatch( {}, "Calcium Limit Summaries", OutlineBox, {Close( 1 )} )
	By(:LOC_NAME)
for(c=1, c<=NItems(ccb), c++,
	thisrep = Report(ccb[c]);
	firstOB = thisrep[OutlineBox(1)];
	thistitle = firstOB << getTitle;
	firstOB << save picture ("desktop/"||thistitle);
Here is one of the methods that I use to create multiple columns of output
Nw = New Window( "Control Charts",
	Lineup Box( N Col( 2 ),
			Variables( Y( :height, :weight ) ),
			by( :age )
Lharbicht
Thank you for the idea. I changed the script a bit to include a Lineup box. At first I tried with multiple unique names ine the 'by' column. However it was putting a different sample in the second column, rather than splitting up the 6 graphs for each unique name into 2 columns of three. See attached photo.
So I tried again using only one unique value to see if it would split the six graphs into 2 columns and it exported the one unique value in a column of six graphs. It still didn't separate into 2 columns. What am I doing wrong?
Here's a portion of the script.
	Lineup Box( N Col( 3 ),
	Variables(
		Y(
			:Chloride,
			:Cl_TDS,
			:Sodium,
			:Sulphate,
			:Calcium
		Dispatch( {},
			OutlineBox,
			{Close( 1 )}
	),by(:LOC_NAME);
I've also included an example of my dataset if that helps.
Thank you for your help.
Is this what you are looking for?
Nw = New Window( "Control Charts", lb = Lineup Box( N Col( 2 ) ) );
	vlb = V List Box(
			Variables(
				Y( :Chloride, :Cl_TDS, :Sodium, :Total Dissolved Solids, :Sulphate, :Calcium )
	lb << append( vlb );
Lharbicht
I'm looking for them to be transposed basically. See attached picture. Because then I will export each set of 6 graphs as one jpg and insert into powerpoint. See how LOC_NAME = 00-15A has six graphs, and then the next set of six graphs is LOC_NAME = 0016A.
// charts
		Variables(
			Y(
				:Chloride,
				:Cl_TDS,
				:Sodium,
				:Sulphate,
				:Calcium
	nw << append( ob );
Lharbicht
@txnelson Thank you for the script! That is perfect. I was able to modify one portion to allow all 6 graphs of each sample to save on one powerpoint slide. I really appreciate your help, and I enjoyed learning as I read through the script.
Thanks again!
