Jackie_
Evaluation column name from the list
I've a list which contains numeric row values. I want to generate Variability plot based on the row values in list. I tried using Eval but something doesn't seem to work. Can someone assist?
Here's my code
Clear Globals();
dt = Data Table( "Untitled 910" );
dt2 = Data Table( "Soft Bin Summary" );
dad = dt2<< get column names(strings);
r = dt << Get Rows Where( :Yield AlertType == "Wafer" );
bin = dt:Yield iBin[r];
Isocol = {};
For(i = 1, i <= N Items(bin), i++,
	Insert Into(Isocol, Char(bin[i])));
aa_refs = Associative Array( dt:Yield iBin[r], dt:Yield fLimit[r] );
vc2 = dt2 << Variability Chart(
	Y( Eval((Isocol))  ),
	X( :WaferID ),
	Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
	Show Range Bars( 0 ),
	Std Dev Chart( 0 ),
	Points Jittered( 1 ),
For( i = 1, i <= N Items( Isocol ), i++,
If( Contains( aa_refs, Isocol[i] ),
Report( vc2[i] )[Framebox( 1 )] << DispatchSeg( CustomStreamSeg( 3 ), {Line Width( 2 )} );
Report( vc2[i] )[AxisBox( 1 )] << {Add Ref Line( aa_refs[Isocol[i]], "Solid", "Dark Green", "T", 2 )};
Re: Evaluation column name from the list
If I delete the "0" from Isocol I do get Variability charts created just fine?
For lines you are comparing characters and numeric values and Contains won't find any matches. Also for some reason you have to divide your aa_ref values by 100
dt = Data Table("Untitled 910");
dt2 = Data Table("Soft Bin Summary");
dad = dt2 << get column names(strings);
r = dt << Get Rows Where(:Yield AlertType == "Wafer");
Isocol = {};
// 0 is last value, so we won't include it
For(i = 1, i < N Items(bin), i++,
aa_refs = Associative Array(bin, dt:Yield fLimit[r]);
	Y(Eval((Isocol))),
	X(:WaferID),
	Analysis Type("Choose best analysis (EMS REML Bayesian)"),
	Show Range Bars(0),
	Std Dev Chart(0),
	Points Jittered(1),
For(i = 1, i < N Items(Isocol), i++,
	If(Contains(aa_refs, Num(Isocol[i])),
		Report(vc2[i])[Framebox(1)] << DispatchSeg(CustomStreamSeg(3), {Line Width(2)});
		Report(vc2[i])[AxisBox(1)] << {Add Ref Line(aa_refs[Num(Isocol[i])] / 100, "Solid", "Dark Green", "T", 2)};
You have one "column" in Isocol which isn't found from dt2, "0".
Jackie_
We can neglect that 0 value
Isocol = {};
	Y(Eval((Isocol))),
	X(:WaferID),
	Show Range Bars(0),
	Std Dev Chart(0),
	Points Jittered(1),
Jackie_
Thanks @jthi . I am still trying to get ref line fixed
