EMB
EMB
Entering dates into data table from dialog box
I'm looking to enter a date into a specific row in a data table after the user inputs it from a dialog box (ex: into row 5). Is there a way to do this?
Thanks
Names default to Here(1);
dt = New Table( "Untitled",
						New Column( "Date 1", Numeric, "Continuous", Format( "yyyy-mm-dd", 12 )),
						New Column( "Date 2", Numeric, "Continuous", Format( "yyyy-mm-dd", 12 )),
q = New Window( "Enter Dates",		// Window for entering dates
		Spacer Box( size(500, 30)),
    H List Box(
		Spacer Box(Size(100, 10)),
		V list box (
		    Spacer Box(Size(10, 15)),
            Text Box("Enter Dates (yyyy-mm-dd)"),
            Spacer Box(Size(10, 20)),
			Text Box("Enter Date 1"),
			Spacer Box(Size(10,10)),
			fontobj = da =  Number Edit box(),
				da << Set Format( Format("yyyy-mm-dd", 12)),
				da << Set (Date MDY ( 12, 31, 2000)),
			Text Box("Enter Date 2"),
			fontobj = db =  Number Edit box(),
				db << Set Format( Format("yyyy-mm-dd", 12)),
				db << Set (Date MDY ( 12, 31, 2000)),
    Button Box( "Continue",
		//code for adding dates to data table
		q <<closewindow;
Re: Entering dates into data table from dialog box
Here is a modification to your code to handle both the text input of date, and the numeric input of date.  Also note that one has to add rows to the data table before they can be populated.
	New Column( "Date 1", Numeric, "Continuous", Format( "yyyy-mm-dd", 12 ) ),
	New Column( "Date 2", Numeric, "Continuous", Format( "yyyy-mm-dd", 12 ) ),
dt << add rows( 1 );
	Spacer Box( size( 500, 30 ) ),
	H List Box(
		Spacer Box( Size( 100, 10 ) ),
		V List Box(
			Spacer Box( Size( 10, 15 ) ),
			Text Box( "Enter Dates (yyyy-mm-dd)" ),
			Spacer Box( Size( 10, 20 ) ),
			Text Box( "Enter Date 1" ),
			Spacer Box( Size( 10, 10 ) ),
			fontobj = da = Number Edit Box(),
			da << Set Format( Format( "yyyy-mm-dd", 12 ) ),
			da << Set( Date MDY( 12, 31, 2000 ) ),
			Text Box( "Enter Date 2" ),
			fontobj2 = db2 = Number Edit Box(),
			db2 << Set Format( Format( "yyyy-mm-dd", 12 ) ),
			db2 << Set( Date MDY( 12, 31, 2000 ) ),
		dt:Date1[1] = da << get;
		dt:Date2[1] = Informat( db2 << get text, "yyyy-mm-dd" );
		q << closewindow;
	H List Box(
		V List Box(
		q << closewindow;
EMB
EMB
