SamKing
Embedding a table script into a table that is generated by an embedded table script
I have a script that adds some embedded table scripts for graphing. I'm now trying to add another table script that creates a summarized table and embeds a new table script inside that new table.
So the embedded table in dt runs fine, opens dtsum as expected except "secondary table script title" does not embed into dtsum. If I run that portion of the script (CTL+R) then it embeds to dtsum.
Note that I have sanitized the script to hide some company IP stuff. Are you able to see something wrong with my format/structure?
dt << New Script(
	"First level Table script title",
	dtsum = dt << Summary(
				// summary details
	dtsum << New Script(
		"Secondary table script title",
		// graph builder details here
Re: Embedding a table script into a table that is generated by an embedded table script
Add the table script to dt_sum in same table script as you create the summary. It might be enough if you just replace , with ;.
dt << Delete scripts(dt << Get Table Script Names); // has many of these already
dt << New Script("Create Summary",
	dt_sum = Current Data Table() << Summary(
		Group(:name),
		Mean(:height),
		Mean(:weight),
		Freq("None"),
		Weight("None"),
		Link to original data table(0)
	dt_sum << New Script("Plot",
		Graph Builder(
			Size(528, 458),
			Show Control Panel(0),
			Variables(X(:name), Y(:"Mean(height)"n), Y(:"Mean(weight)"n, Position(1))),
			Elements(Bar(X, Y(1), Y(2), Legend(4)))
		Group(:name),
		Mean(:height),
		Mean(:weight),
		Freq("None"),
		Weight("None"),
		Graph Builder(
			Size(528, 458),
SamKing
Looks like your last sentence was correct, I just needed to replace the , with ;
I thought my format was good and that I had something more broken than that, I appreciate the quick response! Thanks!
