cjackso21
Convert Date to a format used for chart reference lines
I want to take a list of dates from one table and use them as reference lines in an X by Y with Date as the X axis.
The date formats are in this format from a table: 12/18/2023 14:14.  I would also like to add the label to each line from the same table.  In this case it is EPOXI MT25700-02
The script for the chart shows what I would like be able to add from a table to the chart as reference lines.   I would like to take the list of dates and lot numbers from a separate table and make them reference lines in a chart.
Bivariate(
	Y(:Value),
	X(:CreatedDateTime),
	Where(
		:ValueName == "Dispense Weight Chec" & :Site == "SAN" & :ProcessName ==
		"CLOUE Unload Station" & :EQNumber == "EQ-902280-001"
		Dispatch(
			"CreatedDateTime",
			ScaleBox,
			{Add Ref Line(3785753640, "Solid", "Black", "EPOXI MT25700-02", 1)}
		Dispatch({}, "Bivar Plot", FrameBox, {Frame Size(910, 194)})
Re: Convert Date to a format used for chart reference lines
If this is the form of the graph that you want
Here is the JSL that produces the above graph
Data Table( "Weight Checks for JP" ) << Bivariate(
	Y( :Value ),
	X( :CreatedDateTime ),
	Where(
		Dispatch(
			"CreatedDateTime",
			ScaleBox,
			{Label Row( Label Orientation( "Angled" ) )}
		Dispatch( {}, "Bivar Plot", FrameBox, {Frame Size( 910, 194 )} )
BivR = Current Report()[Outline Box( 1 ), AxisBox( 2 )];
For( i = 1, i <= N Rows( Data Table( "Bottle Change Data" ) ), i++,
	BivR << Add Ref Line(
		Informat( Data Table( "Bottle Change Data" ):Date_Time[i], "m/d/y h:m" ),
		"Solid",
		"Black",
		Data Table( "Bottle Change Data" ):Description[i] || "  " ||
		Data Table( "Bottle Change Data" ):Part_Number[i],
		1
Please use the <JSL> icon at the top of the Discussion Entry area when you are entering JSL.  It makes the reading of the code much easier
