I did DOE to look at some factors if they have any effect onmy output and got this effect summary report from the regression analysis. In the following effect summary bar for the B*C interaction is not crossing the blue line but p-value is less than 0.02. So is this interaction significant or not? To conclude which factor is significant do we lok at blue line or p-value?
The blue line is drawn at 99% confidence for the terms. So the term in question is significant at the 95% confidence level, but not at the 99% confidence level.
