ComplexNerd
Editable Report Preview in application Builder
Hello guys,
I am using applciation builder to select name of report from the list box and its preview will be displayed
// This function will run on selection of each item in list box
reportPreviewPrint = Function( {thisBox},
	{Default Local},
//Get selected report name from the list box of open report names
	selectedReport = ListPrintReport << Get Selected;
	wList = Get Window List( Type( "Reports" ) );
	ReportNames = wList << get window title;
	previewList = {};
	reportTitle = {};
	If( N Items( selectedReport ) > 0,
		abc = ReportPanel1 << Child;
		abc << Delete;
		For( j = 1, j <= N Items( wList ), j++,
			For( i = 1, i <= N Items( selectedReport ), i++,
				If( ReportNames[j] == selectedReport[i],
					Insert Into( previewList, wList[j] );
					Insert Into( reportTitle, ReportNames[j] );
// After going through all open reports and finding the selected report i display it in the panel box
		If( !Is Empty( previewList ),
			ReportPanel1 << Append( previewList[1] )
		ReportPanel1 << Set Title( Concat( "Report Preview/Print Reports/", reportTitle[1] ) );
My question is there there a way to display this report such that any changes made on this (the panelBox is enabled) will affect the original report (like axis changes or backgound color or legend etc).
Re: Editable Report Preview in application Builder
The report being displayed after appending into the Panel Box is a copy of the original report.  This is similar to creating a Journal.  In general JMP Platforms cannot have multiple views of the analysis that are all "live".
