MannPuppy432
Dunnett Quantile
some body can help me on this formula, why i cannot give 4 numbers on this ?
Re: Dunnett Quantile
My guess is that it is related to the other inputs you are using Dunnett Quantile(1-alpha, nTrt, dfe, <lambdaVec=.>)  (I'm not familiar with this function).
Dunnett Quantile(0.95, 3, 11, [1 2 3 4]);
Will throw an matrix dimension error
matrix dimensions are incorrect for operation in access or evaluation of 'Dunnett Quantile' , Bad Argument([1 2 3 4]), Dunnett Quantile/*###*/(0.95, 3, 11, [1 2 3 4])
and this won't
Dunnett Quantile(0.95, 4, 11, [1 2 3 4]);
MannPuppy432
my formula is so simple, but somehow JMP inform error on lamdaVec
Dunnett Quantile(0.95, 1, 146, [0.7]);
For me your example works fine (using JMP 17.2)
If lambdaVec isn't matrix it will throw an error (0.7 instead of [0.7])
