  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
lala
Level IX
Plotting gradient colors in JSL, how to use variables to represent specific parameters?
For example, the maximum and minimum values of this:
{gradient({Scale Values([200000 0 -200000])})}
mx=200000
mn=-200000
{gradient({Scale Values([ma 0 -ma])})}
Re: Plotting gradient colors in JSL, how to use variables to represent specific parameters?
This is my old school way of handling this:
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = dt << Treemap( Categories( :city ), Sizes( :POP ), Coloring( :CO ) );
treemapGBPref = Get Platform Preference( treemap( "Use Graph Builder" ) );
prefVal = Arg( Arg( Arg( treemapGBPref, 1 ) ) );
mx = 20;
mn = 1;
report = obj << report;
Eval(
	Parse(
		"report << Dispatch(
		\!"400\!",
		ScaleBox,
		{Legend Model(
			1,
			Properties(
				0,
				{gradient( {Scale Values( ["
		 || Char( mn ) || " " || Char( mx ) || "] )} )},
				Item ID( \!"CO\!", 1 )
When all else fails, this method always works.  You need to learn it and put it into your tool box.
lala
Level IX
Thank Jim!
hogi
Level XIII
As an alternative you could create the matrix outside of the command and use it via Name Expr(range)
range = [1 20];
(obj << Get Legend Server()) << Legend Model(
	1,
	Properties(
		0,
		{gradient( Scale Values( Name Expr( range ) ) )}
