manny_uy
Does anyone know if there is an Add-in to read MATLAB data tables into JMP?
I am trying to open a data table that was generated from MATLAB. Apparently, it is not like opening an Excel or Text file.
ian_jmp
Level X
Re: Does anyone know if there is an Add-in to read MATLAB data tables into JMP?
If you have MATLAB on the same machine as JMP, this should help: Working with MATLAB
manny_uy
Ian,
It does not seem economical to spend money to install MATLAB so that I can open a MATLAB data file. Besides, if one already has MATLAB, opening up a MATLAB file is then not a problem. I was looking for someone to write an ADD in so that I don’t need to purchase MATLAB.
Manny
You don't need MATLAB on your computer to be able to work with files from Matlab. If your files are in matlab data format (.m or .M), JMP Pro has the capability to upload it. All you need to do is Click on File>Open and in the pop-up window select from the file type .m or .M and >open.
Jenkins Macedo
manny_uy
Macedo,
Thanks for pointing this out for me. I should have looked more carefully at all possible files that JMP can open.
Now for another problem – how can I open data files in Microsoft Access?
Manny
If you have the data is MS Access, save it as an Excel file and input that to JMP is one solution. Here is a quick link to JMP Help on Data Import processes.
Import Your Data
However, if you have an Access Database on the same computer or network as JMP, you can use JMP Open Database Connectivity) ODBC to access file in an MS Access database. Here is a link: Import Data from a Database
Jenkins Macedo
Why would you purchase Matlab, if JMP can open it or is your question more specifically about a JMP Add-in that is MatLab specific? Either way, it isn't viable given that JMP already has that capability to upload Matlab file and than transform it to a .jmp data file.
Jenkins Macedo
ian_jmp
Level X
Not that it matters now, but in my attempt at multi-tasking the first line of my reply was omitted:
Please see: http://www.jmp.com/support/help/About_Importing_Data_to_JMP.shtml#468168
