HelenaG
DoE - Continuous factors not allowing to set the decimal format
When I try to insert a decimal number in a continuous factor of DoE: it does not allow it. It appears a huge number like the below (instead of 2.2 that I inserted. I tried with "." and "," and the result is always this):
How can I solve this?
Thank you in advance,
Helena G.
Phil_Kay
Re: DoE - Continuous factors not allowing to set the decimal format
Hi @HelenaG ,
I can't reproduce that problem (I am using JMP Pro 17.1).
I suggest that you contact JMP Technical Support ([email protected]) so that they can look at this. They will need to know what version of JMP you are using.
I hope that helps,
Phil
I also cannot reproduce the error (V.17.0)?  Phil, you are on 17.1?  I do not find that available.
Phil_Kay
I'm using a pre-release build of 17.1. (Staff only). 17.1 will be publicly available very soon.
