DoE - Continuous factors not allowing to set the decimal format
Created:
Mar 20, 2023 08:26 PM
| Last Modified: Jun 8, 2023 2:13 PM(2390 views)
When I try to insert a decimal number in a continuous factor of DoE: it does not allow it. It appears a huge number like the below (instead of 2.2 that I inserted. I tried with "." and "," and the result is always this):
I can't reproduce that problem (I am using JMP Pro 17.1).
I suggest that you contact JMP Technical Support ([email protected]) so that they can look at this. They will need to know what version of JMP you are using.
