Do Not Open CSV File after 'Save As' when scripting
Oct 4, 2023 12:13 PM(3203 views)
I need to save tables by scripting both as .csv and then as .jmp.
When the .csv table is saved, it is automatically opened in excel (Win 11, JMP17Pro). Is there a way to set an option (or preference) to prevent the behavior?
It does not open excel. I ran another test for obviously it's working fine. Not sure why I was experiencing that issue. Thanks for the help nonetheless
