kgbrown1963
Distribution Platform Preferences -- Default Prediction Interval Generation
I would like to set up the default for the Distribution platform (Continuous variable) to automatically (by default) generate Prediction Intervals (two-sided 0.95, n =1) so that I can capture the results into a Data Table using a JSL script. I see several defaults (e.g., confidence, tolerance, etc.) that can be set in the Preferences menu for the Distribution platform, but not any for Prediction Intervals (PI's). I know that I can generate PI's for multiple distribution results by Ctrl-clicking the "Prediction Interval" selection from the Results drop-down menu, but I would rather have these generated by default, so I can capture the results into a Data Table using a JSL script. I do not believe the "Ctrl-click" PI selection is "scriptable." From a previous post (and thank you all), I know how to generate the desired combined Data Table after I have the PI results.
I have just started using JMP Student Version 18.2.0; I had JMP Pro until this year.
kgbrown1963
Re: Distribution Platform Preferences -- Default Prediction Interval Generation
Jarmo,
I apologize for my slow response. When I suggested that the "Ctrl-click" PI selection was not "scriptable," I (mistakenly) meant that the selection does not show in the JMP log. However, your suggestion does appear to give me the desired results when I add the PL option to the Distribution platform call, e.g.:
obj = dt << Distribution(Column(:Height, :Weight), Prediction Interval(0.95, 1) );
Thank you for your help.
Kevin
There really isn't many things that are not scriptable in JMP. By Ctrl+Click do you mean broadcasting? So you have multiple distributions and wish to use same settings for all of them?
obj = dt << Distribution(Column(:Height, :Weight));
obj << Prediction Interval(0.95, 1);
kgbrown1963
Jarmo,
Kevin
For me it does get recorded to the log if I do it manually first. I have this report
And if I copy script from red triangle I get the following
Distribution(
	Continuous Distribution(
		Column(:height),
		Process Capability(0),
And if I close the platform (that is the moment when log gets the "proper" script for the platform, otherwise it is just Launch script if even that)
