BiX
BiX
Display PNG image from URL into a Wafer Map
I would like to see a wafermap from CSV file ... ok
but I would replace each square by an PNG image from URL  defined into the same CSV file ...
Do you have some ideas how to do ???
17 REPLIES 17
BiX
BiX
Re: Display PNG image from URL into a Wafer Map
hi Jthi, thanks for your help.
But I obtain circles instead pokemon images .... a graph parameter to change ?
Graph builder might be plotted from wrong data table. Based on window names: graph builder is using table Wafermap_pokemon_2 and data table is which is visible is Wafermap_pokemon_2 2). Maybe Wafermap_pokemon_2 data table doesn't have Image column properly set?
BiX
BiX
Hi Jthi,
thanks again.
Sorry, I have always point or circle instead of pokemon images.
I suspect  the command "Set Shape Column(:Images))" is not functional on my side ?  (in V15.0.0 or V15.2.1)
I'm not sure when it has been implemented (I'm using JMP16). You could try using the Images column as Marker column I suggested in my first message in this thread. Hopefully that works (you will have to remove that part from graph builder in that case I would think).
@jthi  has a good suggestion. Set Use for Marker was implemented in JMP 14 according to the Scripting Index:
When using a function for the first time, it's good to look it up in the Scripting Index under the Help menu.
You may also want to turn on the embedded log in the script editor, (Right-click > Show Embedded Log)  so you can see errors when you run your script.
Hope this helps,
~John
BiX
BiX
Thanks John,
I try to put in place your proposal inside Jthi's script without success ...
Please could you propose to me your update ?
rgds
dt = Open(
"$DOWNLOADS/pokemons/Wafermap_pokemon.csv",
Import Settings(
End Of Line(CRLF, CR, LF),
End Of Field(Comma, CSV(1)),
Strip Quotes(0),
Use Apostrophe as Quotation Mark(0),
Use Regional Settings(0),
Scan Whole File(1),
Treat empty columns as numeric(0),
CompressNumericColumns(0),
CompressCharacterColumns(0),
CompressAllowListCheck(0),
Labels(1),
Column Names Start(1),
Data Starts(2),
Lines To Read("All"),
Year Rule("20xx")
dt:XCoord << Data type(Numeric) << Set Modeling Type(Ordinal);
dt:YCoord << Data type(Numeric) << Set Modeling Type(Ordinal);
// reduce Filename to only filename OR use full filepath and modify Images column's formula
dt:Filename << Set Each Value(Word(-1, :Filename, "\"));
Show(Get Default Directory());
// This can be modified to get borders and so on if needfed
dt << New Column("Images", Expression, None, << Set Each Value(
Open(Get Default Directory() ||"images/" || :Filename, png);
height = 20;
weight = 20;
gb = dt << Graph Builder(
Size(522, 451),
Show Control Panel(0),
Variables(X(:XCoord), Y(:YCoord)),
:Images << Set Use For Marker;
Bivariate( Y(:height),X(:weight) );
Bivariate[]
Hi @BiX ,
The example I showed was for use with the Big Class Families.jmp sample data set. 'height', 'weight,' and 'picture' are columns in that data set, but are not in the table you create in your script.
To use 'Set Use For Marker' in your script, you need to send the 'Set Use For Marker' message to the 'Images' column that you create in your script before the Graph Builder function.
To do this, replace everything starting with 'height = 20;' to the end with the following:
	Size( 522, 451 ),
	Variables( X( :XCoord ), Y( :YCoord ) ),
	Elements( Points( X, Y, Legend( 1 ) ) ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Marker Size( 15 ), Marker Drawing Mode( "Normal" )}
Notice that I added back the SendToReport code to set the Marker Size to 15 that you had earlier in this post.  If you change the size of the graph, you may want to change the Marker Size too.
Please let us know how that works out for you.
Thanks,
~John
BiX
BiX
Hi John,
Thanks a lot !! Superbe !!
Thanks a lot Jthi,  for your help and your solution for JMP > v16
Solution for JMP v15 below
Merry Christmas
Xavier
Script JMP V15 :
// JMP V15
dt = Open(
	Import Settings(
		Strip Quotes(0),
		Scan Whole File(1),
		Labels(1),
		Data Starts(2),
		Year Rule("20xx")
	Size( 522, 451 ),
		Dispatch(
			"Graph Builder",
			FrameBox,
