AmanS
Disabling screen updates
I have a script that does lots of table operations like Stack, update, split , summary etc. Each operation displays a table once it is complete. I wanted to ask if there is a way to halt the screen updates at the beginning of the script and then turn them back on at the end of it.
Something like this..
//Open Data Table and set to invisible
dt = Open(file,invisible);
// Turn off screen update?
summaryABC = dt<< Summary(Group (:A,:B,:C); // This opens the table that I would like to hide
SummaryAB = summaryABC << Summary(Group (:A,:B);
// other misc table operations
//turn on screen update?
Thanks for your help.
Re: Disabling screen updates
Here is a generalized way of dealing with this.  The Show Window() function can be used on almost every window, if no all windows, to have them displayed or not displayed.
names default to here(1);
dt=open("$SAMPLE_DATA/big class.jmp");
dt << show window(0);
wait(5);
dt << show window(1);
Thierry_S
summaryABC = dt<< Summary(Invisible, Group (:A,:B,:C); // This hides the Summary ABC table
summaryABC << Bring Windows to Front; // This brings Summary ABC to the front
Have you considered using the "Invisible" switch in your Summary command (see above)? You can then bring back the window with "Bring Window to Front".
Note: I have not found the exact command line to turn on and off the hidden status of a window.
Best,
TS
Thierry R. Sornasse
wait(5);
AmanS
@txnelson  Just like old times you set me straight and get me working! Thanks for taking the time. Nice to see you here..
Jeff_Perkinson
There is no general "don't show data tables" statement.
However, almost every data table operation supports an invisible or private option to keep the data table from appearing.
-Jeff
AmanS
@Jeff_Perkinson , Appreciate it. I will read through this
Thierry_S
Best,
TS
Thierry R. Sornasse
Thierry_S
Oops,
txnelson provided a much nicer solution.
Best,
TS
Thierry R. Sornasse
AmanS
@Thierry_S  Thanks for taking the time. I appreciate it. I like the use of invisible and I decided to use a mix of both yours and Jim's solution.
