Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
View Original Published Thread
Different mixture experiment analysis results JMP 17 & 18
frankderuyck
Did something in JMP 18 change in analysis of mixture experiment results. Below is shown that analysis results from exactly the same DOE data sets are different
1. DOE three component mixture
JMP 17 results
JMP 18 Results
2. DOE three mixture components + one process effect
JMP 17 results
JMP 18 results
In JMP 18 analysis above the model is different!
What has changed and why? Remark: despite of different plots & model graphs of JMP 17 - 18 prediction profilers are identical.
13 REPLIES 13
statman
Re: Different mixture experiment analysis results JMP 17 & 18
I'm not sure the correct word is accurate...different, yes.  It appears the JMP18 version looks more like a leverage plot than the one from JMP17.  Typically those plots are narrowest in the center and expand near the ends.  Collinearity is typically a cluster of points near the middle.
https://www.jmp.com/support/help/en/18.1/#page/jmp/effect-leverage-plots.shtml?os=mac&source=applica...
frankderuyck
The DOE analysis script is 100% reproducible both in JMP 17 and 18.  When running second DOE (mixture + process effect) analysis script, developed in jmp 17, in jmp 18 besides the prediction plot also model is different (?) The prediction profilers always are equal.
statman
Yes, but in your initial post, the statistics were different as well. That does not appear to be a JMP issue.
frankderuyck
As in case 1 the case 2 data set and analysis script are exactly the same, indeed now results are also different..
Only difference is the two jmp versions
