Chitranshu
Delta between clusters? JMP PRO
For a set of data clustered into two groups and plotted against other variable on X axis. Is it possible to determine the delta comparing both clusters.
Victor_G
Re: Delta between clusters? JMP PRO
Hi @Chitranshu,
Which clustering technique do you use ?
If I understand well your question, you can have access to cluster mean results of the X variables used in the clustering.
  • Example with Hierarchical clustering (click on red triangle, "Cluster Summary" to display the summary) on Big Class dataset with 5 clusters:
  • Example with K-Means on Big Class dataset with 2 clusters:
  • Same display for Normal Mixtures :
So you can use these information to calculate the mean distances for each X variables between the 2 clusters you have.
Hope I get your question right,
Victor GUILLER
Victor_G
Hi @Chitranshu,
Victor GUILLER
