Zero-inflated negative binomial model - random effects?
Created:
May 29, 2023 09:27 AM
| Last Modified: Jun 10, 2023 1:55 PM(2971 views)
I have several random variables I'd like to add to my ZINB model (individual, month), but I cannot sort out how to include those in the fit model personality. Is there an add-in or something I could use?
A model for a response with a zero-inflated negative binomial distribution requires the Generalized Regression fitting personality to be selected in the Fit Model dialog. This platform is only available in JMP Pro.
Thank you - Yes, I see the generalized regression personality, but unlike the GLMM there isn't a tab to put in random effects. I am curious how I can put in a random effect into this personality.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '636444' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '636444') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '636444') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
