kcorder
Deleting specified rows
Hey JMP community, I am extremely new to jmp/jsl (literally just started this week). I have a script that is supposed to select where certain values in a row are less than 3, and then delete those rows. This is the script I have to do so:
dt << select where( :Residual 1 <= 3 );
dt << delete rows;
The code correctly selects the rows I want it to, but upon deleting the rows they "update" themselves (I have a neural network model scripted into the lines before it... see below code).
// 1. Creates X1 column, and corresponding Y1 and Ystat columns
Close All( Data Tables, NoSave );
dt = New Table( "SampleRun 3",
	Add Rows( 100 ),
	New Script(
		"Ystat vs. X1",
		Graph Builder(
			Variables( X( :X1 ), Y( :Ystat ) ),
			Elements( Points( X, Y, Legend( 5 ) ) )
	New Column( "X1",
		Formula( Random Integer( 50 ) )
	New Column( "Y1",
		Formula( If( :X1 < 25, 2 * :X1, 25 <= :X1 <= 30, 3 * :X1, 4 * :X1 ) )
	New Column( "Ystat",
		Formula( :Y1 )
// 2. Creates predicted Ystat column, saves formulas into same data table (first iteration)
PredictedYstat = dt << Neural(
	Y( :Ystat ),
	X( :X1 ),
	Informative Missing( 0 ),
	Validation Method( "Holdback", 0.3333 ),
	Fit( NTanH( 3 ) )
PredictedYStat << Save Profile Formulas;
// 3. Adds residual column
dt << New Column( "Residual 1", Formula( Abs( :Predicted Ystat - :Ystat ) ) );
dt << select where( :Residual 1 >= 3 );
dt << delete rows;
I am able to select these rows and put them into a new table, but that is a last resort as it is inefficient. Any suggestions?
Thanks,
Kyle
Re: Deleting specified rows
If you want the Formulas to evaluate once and only once, one option would be to force the computation and then delete the formulas:
dt << Run Formulas;
Column(dt, "X1") << Delete Formula;
Column(dt, "Y1") << Delete Formula;
Column(dt, "Ystat") << Delete Formula;
dt << Run Formulas;
kcorder
This worked, thank you!
