Delete rows based on 2 conditions
Hi, I have a data table "Table1", I need to have a JSL script that deletes rows based on both "TesName" & "Cpk" columns conditions.
First condition, column "TestName" will have repeated rows for example DOE for multi doses (same testname) that yields different Cpks; 2nd condition, I need to keep the row with lowest Cpk and delete the rest. Output of Table 1 is what you would expect from the script
Thanks in advance,
Sam
gzmorgan0
Re: Delete rows based on 2 conditions
Try this
dt  = current data table();
dt << New Column( "MinCpk", numeric, formula(Col Minimum( :Cpk, :TestName )));
dt << select where(:Cpk > :MinCpk);
dt << delete rows;
dt << delete Column("MinCpk");
//___________________________________________________________
//or use this to keep the original table and create a new table with only the rows of interest
dt << New Column( "MinCpk", numeric, formula( Col Minimum( :Cpk, :TestName ) ) );
idx = dt << get rows where( :Cpk == :MinCpk );
newtbl = dt << subset( Rows( idx ), All Columns, Output Table Name( "Table2" ) );
newtbl << delete columns( "MinCpk" );
uday_guntupalli
Level VIII
@Anonymous,
     The following example illustrates how you can apply it to your case.
Show(n Rows(dt));
dt << Select Where(:age == 12 & :height > 60);
dt << Delete Rows;
Show(n Rows(dt));
Best
Uday
Hi Uday, I tried it did not work, my case conditions are dunamic
thanks
Sam
I got this script to get me closer but final table still missing other data from other columns, Split, Mean, Sigma, Min, Median, Max
dt << Summary( Group( :T
Untitled.jpgestName), Min( :Cpk ));
sorry code was cut by image
dt << Summary( Group( :TestName), Min( :Cpk ));
gzmorgan0
Try this
dt << delete rows;
Thank you very much, it works perfectly.
Regards
Sam
