joelahn
Default encoding on JMP - EUC-KR
I have JMP 14.2, 15.1, and also 16.0EA at the moment.
All versions here don't include EUC-KR encoding system; so this can cause importing problems in many cases since a lot of Korean data or pages are made with EUC-KR. I have charsets that are all broken. So I had to import it with other programs and save as to fit into UTF-8 or match/join columns with other matching codes.
It seems like JMP is adopting EUC-JP as option. Will there be any possibility of adding EUC-KR as per flexibility of importing files? Or is there anything that I am misunderstood that it can be sorted out without this?
Joel Ahn
Lam Research Corporation
Mobile +82 10 9509 0109
0 REPLIES 0
