  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
thickey1
Adding a table to a display object
I am trying to build an User Interface which must incorporate a JMP Data Table. Beeen browsing around but cannot seem to figure it out.
In pseudo code I want to do something like this whereby I kick off a platform and a data table is present. In the course of my JSL running I will then populate/write to this data table 'live'
DT = newTable("Test")
Platform = new Window("App", DisplayBox(DT))
 hope this makes sense :)
Re: Adding a table to a display object
Look in the Scripting Index for "New Data Box()"
dtA = Open( "$SAMPLE_DATA/Big Class.jmp", invisible );
New Window( "school",
	H List Box(
		dtA << New Data Box(),
		Text Box(),
		dtA << Distribution(
			ContinuousDistribution( Column( :weight ) ),
			NominalDistribution( Column( :age ) )
	H List Box(
		Text Box(),
thickey1
Thanks Jim. I learned something new based on your reply.......in JMP 15 all Messages are shown clearly in the Scripting Index and I see this example there also. Exactly what I needed. Cheers, Troy
