  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
lucianoa
Default Y-axis scale for multiple charts in graph builder, using page function
I am using graph builder for a data set that produces 20+ graphs.  I would like the scale & range of the Y-axis to be the same for all 20 graphs.  I tried the script below with no success
Graph Builder(
Variables( X( :Date ), Y( :Rate ), Page( :Category ) ),
Elements( Line( X, Y, Legend( 5 ) ) ),
Dispatch(
eval( column( :Rate)),
ScaleBox,
{Min( 0 ), Max( 50 ), Inc( 10 ),
Minor Ticks( 10 )}
Jeff_Perkinson
Re: Default Y-axis scale for multiple charts in graph builder, using page function
It's probably easiest to use the Axis column property on your :Rate column. That will make sure the axis is always what you want, and it's easier than trying to get to all the axes across reports to format them.
-Jeff
