fionaweston
JMP to MongoDB connection.
I am reading back to posts from 2019 that say there is not a native connection in JMP for mongo-db. Is this still the case?
Our ERP system runs Mongo DB and we'd like to connect to JMP (16). Is it possible yet?
Thanks
Re: JMP to MongoDB connection.
Hi Fiona,
Access to Mongo through JMP will require an ODBC driver.  There are a variety out there, some of which you must pay for.  Once you set up the driver with your Mongo connection information you can use the JMP Query Builder or Database Open Table capabilities.  Most databases like Oracle or SQL Server require the same kind of preparation prior to importing data into JMP.
Brian Corcoran
JMP Development
ih
Super User (Alumni) ih
You can also utilize R or python for this:
R Init();
R Submit("
library(mongolite)
connection_string = 'mongodb+srv://<username>:<password>@<cluster-name>.mongodb.net/sample_training'
trips_collection = mongo(collection=\!"trips\!", db=\!"sample_training\!", url=connection_string)
user_types = trips_collection$aggregate('[{\!"$group\!":{\!"_id\!":\!"$usertype\!", \!"Count\!": {\!"$sum\!":1}}}]')
df <- as.data.frame(user_types)
dt = R Get(df);
R Term();
Example R Syntax is from: https://www.mongodb.com/languages/mongodb-and-r-example
Hi Fiona,
Brian Corcoran
JMP Development
ih
R Init();
R Submit("
library(mongolite)
dt = R Get(df);
R Term();
