With a continuous response variable, the Difference appears to be the difference between the 2 means for the next split in the tree.  I don't know why that calculation is placed in the point in the tree above where the split is done, but if you look at the splits, you will see that each split shows the mean for each branch and the difference between these means appears with the point of the tree just above that split.
