ConvergentWhale
Decimals on y axis on plots
I use a simple JMP add-in that outputs some plots. Is there anything I could do to change the decimal precision of the y-axis without having to manually adjust it each time?
How it is now:
how i would like it :
The script that i use is this :
					gb1 = Expr(
						Graph Builder(
						Size( 635, 338 ),
						invisible,
						Show Control Panel( 0 ),
						Variables( X( :Time Point Months ), Y( :Result ), Overlay( :Batch ) ),
						Elements(
							Points( X, Y, Legend( 1 ) ),
							Line Of Fit( X, Y, Legend( 2 ), Confidence of Fit( 0 ) )
						Local Data Filter(
							invisible,
							Add Filter(
								columns( :Component, :Batch, :Source Table ),
								Where( :Component == numPar[i] ),
								Where( :Batch == {cyc[k], bat[k]} ),
								Where( :Source Table == dt_name )
							Dispatch(
								"Time Point Months",
								ScaleBox,
								{Min( -0.1 ), Max( maxvalts ), Inc( 2 ), Minor Ticks( 1 )}
							Dispatch(
								"Result",
								ScaleBox,
								{Min( Eval( minval )), Max( Eval( maxval )), Inc( Eval( (maxval - minval) / 10 ))}
							Dispatch(
								"graph title",
								TextEditBox,
								{Set Text( numPar[i] || " vs. Time Point " )}
							Dispatch(
								"Y title",
								TextEditBox,
								{Set Text( yTitleText )}
Re: Decimals on y axis on plots
Modify it in the graph builder, get the script from red triangle menu and then make changes based on that
Graph Builder(
	Variables(X(:weight), Y(:height)),
	Elements(Points(X, Y, Legend(3))),
	SendToReport(Dispatch({}, "height", ScaleBox, {Format("Fixed Dec", 12, 3)}))
