B1234
Date Calendar box
I'm trying to make a jmp application that will run trends. I have two calendar boxes with a "From" and "To" date. When I click the "Run Script" button, I want to be able to use dates defined in the calendar boxes to select dates in my trend. How can I get the values from the calendar boxes to use in the script?
B1234
Re: Date Calendar box
This is what I have tried but doesnt seem to work
NumberEdit1 << set Function( Function( {this}, sd = NumberEdit1 << Get Date() ) );
NumberEdit2 << set Function( Function( {this}, ed = NumberEdit2 << Get Date() ) );
Show( sd );
startdate = Format( sd, "ddMonyyyy" );
Show( ed );
enddate = Format( ed, "ddMonyyyy" );
pmroz
Try something like this:
nw = new window("Test Dates", << modal(),
	Lineup Box( N Col( 2 ),
		text box("Enter start date: "),
		start_neb = number edit box(today(), << Set Format( Format( "ddMonyyyy", 10))),
		text box("Enter end date: "),
		end_neb   = number edit box(today(), << Set Format( Format( "ddMonyyyy", 10))),
	ok_button = button box("OK",
		startdate = start_neb << get;
		enddate   = end_neb << get;
print(format(startdate, "ddMonyyyy" ), format(enddate, "ddMonyyyy" ));
From the log:
"11Apr2022"
"24Apr2022"
pmroz
Didn't realize you were using calendar boxes.  Try this:
	text box("Monitoring & Trending"),
	hlistbox(
		panelbox("From Date",
			cal_start = calendar box(<< Show Time( 0 )),
		panelbox("To Date",
			cal_end = calendar box(<< Show Time( 0 )),
		startdate = cal_start << get date;
		enddate   = cal_end << get date;
you might like Select Date Range with Calendar Boxes Linked calendar boxesLinked calendar boxes
B1234
thank you @pmroz and @Craige_Hales  this was very helpful! working well now thank you both.
