Theresa
Data table - If one column has empty value, then use other column value to fill in,other row keep no change
//If the original data table is like below,
// there are 2 empty value(:sex[3] and :sex[4] )in column sex:
dt:sex[3 4] = black;
I want the function is:
when search all values in column :sex, if find column sex have empty value, then fill the column :name value into the empty position in :sex while keep other value in :sex with no change.
Re: Data table - If one column has empty value, then use other column value to fill in,other row keep no change
One way to script it would be using << set each value with if to check for empty string (if numeric you have to change the if to use IsMissing()).
names default to here(1);
dt:sex[3::4] = "";
dt:sex << Set Each Value(If(:sex == "", :name, :sex));
