andyczerwonka
Data Source SPI
I'm wondering if JMP publishes a service provider interface (SPI) that would allow us to publish a RESTful interface that would be natively consumable via the HTTP connector?
https://www.jmp.com/en_ca/software/analytic-workflow/data-connectors.html
ih
Super User (Alumni) ih
Re: Data Source SPI
Hi @andyczerwonka,  I am afraid I do not understand the question.
  • Does JMP have information that you want other applications to access?
  • Are you trying to access information from other applications and get that into JMP?
  • Are you trying to connect one instance of JMP with another?
All are possible...
andyczerwonka
Re: Data Source SPI
I want to provide an interface to JMP, so that users for JMP could easily pull my data in. This would be in the context of a SaaS application, where the user would configure a REST endpoint and provide and API token, then JMP would be able to import data.
This kind of integration is often done when the vendor (JMP) provides a “service provider interface” (SPI), so that service implementers can provide streamlined data integration. It’s basically a description of a protocol, that if I were to implement, would plug directly into JMP.
Re: Data Source SPI
If you provide a RESTful interface, then JMP can access is via JSL with HTTP Request.
https://community.jmp.com/t5/JMP-Scripts/Integrating-InfluxDB-with-JMP-using-HTTP-Request/ta-p/54551...
https://community.jmp.com/t5/JMP-Scripts/Integrating-Google-Drive-with-JMP-using-HTTP-Request/ta-p/5...
Are just 2 examples.
Does that help answer question?
andyczerwonka
Re: Data Source SPI
The second case mostly describes what I'm after. I have determined that JMP does not support the strategy I was hoping for.
As a data provider,I'd love to be a able to implement a data service interface that JMP could plug into that does not require any custom JSL, that'd be ideal. That is typically achieved through an SPI. That capability unfortunately doesn't exist.
