andrey
Data Filter in JSL script running slow
I am trying to create a JSL script that will utilize data filter and select ~180 tests of interest in "ITEM_NAME" column and create a new table. When I use Data Filter and run it manually it doesn't have any delays. Though when I try to automate the process it takes ~15 minutes to create the new table. What can I do to make it run more efficiently?
Open( "$DOCUMENTS/test.jmp" );
ref10 = Data Table( "ABC" ) << Select Where(
	:ITEM_NAME == "test1" |
	:ITEM_NAME == "test2" |
	:ITEM_NAME =="test3" |
	:ITEM_NAME ==
	"test180"
) << Data View;
Data Table( ref10 ) << Save(
	"$DOCUMENTS/filtered.jmp"
Re: Data Filter in JSL script running slow
Try this
items={"test1" "test2""test3"..........};
	contains(ITEMS) ) << Data View;
It is a bit difficult to understand why your script would be that slow without seeing/understanding your data (it shouldn't be).
You could try using << Get Rows Where and Subset instead of selecting those rows. In this example I have tried to replicate Data View by using linked subset and Untitled output table name
dt = open("$SAMPLE_DATA/Big Class.jmp");
items = {12, 13, 14, 15};
rows_of_interest = dt << get rows where(Contains(items, :age));
dt_subset = dt << Subset(Rows(rows_of_interest), Selected Columns(0), Link to original data table(1), Output Table("Untitled"));
Try this
andrey
Thank you Jim. For some reason I am getting the error (likely syntax related).
andrey
Seems to be running faster now and took around 3-4 minutes to complete but nowhere near as quick if I was to do this manually. Had to make a slight change to the code to avoid the error:
items={"test1", "test2", "test3"..........};
	contains(items, ITEM_NAME) ) << Data View;
My error.....it was late at night....
andrey
Thank you Jarmo. You solution shaved the processing time to about 1:35 seconds.
The JMP table I am using has 13 columns and 13127825 raws. The output file has 1274416 raws.
There are most likely optimizations which could be done but if that speed is enough for your application, I wouldn't worry about those.
